My 66 Bronco will be getting new stock height or up to 1.5" leaf springs (max) installed for future tire size increase from 30' to 31" tires. I currently have some old stock leafs and a 1'' block along with some picnpull F150 coils . Any advice welcome and if a tech article or something similar exists please provide a link. Looking for the easiest method and even half an inch would be good enough for me. I have seen mention of just drilling the axle pad and the u-bolt plate away from the stock hole to accomplish this. Would like to avoid any further modifications unless absolutely needed and understand that lengthening the rear drive shaft may be required. I drive it about 60% on road and 40% on dirt roads but not any heavy duty off road use. I want to start using the Bronco as my daily driver again so getting new springs and shocks package. Probably many Bronco owners are planning this or are in the process of so let me know your strategery please. Thank you.
