needsmoarturbo
- May 13, 2015
- 278
My current setup is 75 bronco with 2" body lift with a stock power steering shaft that has been sleeved to extend it for the BL. I would like to change to a slip shaft for safety and for easy adjustment when i reduce the 2" bl to 1" in the future.
I was looking at the Borgeson lower shafts and the 000976 looks like it would bolt in to the steering box and the rag joint easy peasy. But I saw the 000974 that looks like it has a 3/4"-36 spline on the column end that I have heard is what you will find if you remove the rag joint flange thing off the end of the upper column?
So has any body done this particular job with these parts? is it worth keeping the rag joint for vibration damping, or better to go with the ujoint on the upper end, so I dont have a rotten rubber piece to replace eventually?
below are links to the ones in question.
https://www.cjponyparts.com/ford-br...1316in36-spline-steering-box-inc/p/BRG000974/
https://www.cjponyparts.com/borgeso...opic-steel-1973-1975-ford-bronco/p/BRG000976/
