rmfreeze
Hey guys, I just got through putting a '68 back together and put some trail time on her today. She probably doesn't have 200 miles on the rebuild yet. I put a 351w/C4 in replacing the 200 6cyl / 3-spd.
I used a triple pass radiator but it doesn't have the tranny cooler (or heater if you want look at it that way ;D ). I ran the tranny lines up to the passenger inner fender well and ran them into a B&M cooler with fan. It's mounted with about 1/2" of clearance off the fender.
I had my doubts about the tranny cooler working well in the engine compartment. After doing several test drives I noticed the B&M fan never comes on (175* switch). So I put in a tranny temp gauge and noticed it doesn't heat up AT ALL. It took lots of stop and go driving for it to get above 80* on a 75* day. I knew the radiator helped heat the fluid but I figured it would eventually heat up on it's own. I drove 30 minutes to Superlift ORV Park today and in 65-70* air this morning it never got above 80*. After wheeling for 30 minutes it was around 100*. After 2-3hrs it was 140-160*. If I ever got on a main road and got to 10mph or so for a few minutes it would be down to 100* in no time. It got down to 87* on the way home in 78* air.
Now the motor is another story. I'm using the triple pass radiator and a big electric fan. It's the highest CFM I could find at the time (can't remember what it is). If I'm doing 5mph+, it keeps it 180-190* no problem. But after an hour or so of wheeling it gets into the 200-210* range.
I'm thinking of adding an engine oil cooler and sticking it up front with a small fan. I guess I'll also keep an eye out for a radiator with a tranny heater. I had no idea it would stay that cool without the radiator.
