Too hot to start?
JaxLax
Jacksonville, FL
This has now happened a few times recently (over the course of the year).
Whenever she gets REAL HOT - so long, fast drive, let's say 30 miles on the highway - she will NOT start until cooled way down.
When I try to start, it sounds like the battery is dying/starter dragging. I attempt jumps to no avail. I pulled the battery and it checked OK and had the shop charge it. Dropped it back in and still nothing.
Left it in the Home Depot parking lot last night. Drove up there to either drive home or wait for a tow. And, of course, second tick she fired over.
This was my daily driver for 3 years up until the beginning of this year. She can sit for 2 weeks and still turn over on the second key turn and a gentle tap on the gas without issues. But after a long drive (and the one yesterday was the 5th time I'd started her that day) she just shuts down.
I'm at a loss on what's happening.
And yes, my temp sensor is busted. So I can't even monitor that at the moment.
AC932
How old's the starter? Might just be going out. Mine basically did the same thing 2 summers back, turned over real slow when hot.
Slowleak
Georgia
That can happen if your timing is advanced too much. A hot engine will ignite fuel earlier than a cold one. If it ignites early enough it will fight against the starter. An easy way to tell if that is occurring is to pull the coil wire when it is happening and see if it turns over at normal speed...
SteveL
Huge chevy guy
Hawthorne ca
Harder to start when hot. If it was fine I'm also thinking the starter may be dying. My 72 would eat the chain store cheap lifetime warranty starters in maybe 4 months. Switched to a better one from napa and no problems for years of starts. Theres always the high end stuff like mean green starters but for a stock or mild build it's a little overkill.
pcf_mark
It sounds like the resistance is going up somewhere in the starter circuit. Could be a faulty relay on the fender, crusty wires or a dying starter. If you can carry a volt meter with you check the voltage at the starter lug when someone is cranking. If it is less than 12v your power is being lost along the way. They drop a little but less than 10 is not going to get you cranking. If it is around 11-12v then I would look at the starter. If it is less I would look at the wires (ground and positive) and the fender relay.
I recently had a factory finished wire (nice neat crimps) fail inside - the entire area inside the lug was green with corrosion but it looked new outside.
This video is long but he does a pretty good job of explaining. Jump to 25 minutes for the test you can do quickly.
https://www.youtube.com/watch?v=DfLyh43iihM
Rustytruck
I had an issue like that before. turned out to be a loose ground at the block.
gkling01
What year is your bronco? If you have the duraspark ignition system your magnetic pickup may be failing. Open the distributor cap and inspect the pickup for cracks. If I recall, it is square and blue. These can be replaced by themselves for less than $30. I had these same symptoms happen on my 76. Easy fix if the pickup, I hope you figure this one out!
Sent from my SM-G955U using Tapatalk
Timing is my second thought. First is a heat soaked starter. But timing is easy to check. Unhook the coil and spin the engine over. Without a spark the timing setting doesn't mean anything. It won't start, no spark, but if it spins over quick now you know it is too much timing. If it still struggles, lack of spark makes no difference, timing probably isn't the issue.
Any time a starter drags really slow I like to have it happen at night (preferably at home). Turn on the headlights and watch what happens. Do they go almost completely out? Do they dim a normal amount? Do they barely dim at all? This can point toward excessive resistance in different areas.
JaxLax
JaxLax
Jacksonville, FL
Gonna do this and rent a timing light then.
JaxLax
JaxLax
Jacksonville, FL
Starter is less than a year old.
And the wiring was new 2ga at the same time [I literally melted the wires on a bad starter]
stout22
Athens, AL
Another vote for the starter. This is exactly how mine acted before I had it rebuilt.
EricLar80
If you decide to replace it, get a starter from a late 90's Exlorer with the 5.0L; they have a high-torque starter. Requires you to update the wiring a little, but very worth it. You won't have starter issues again.
elan
s
exact same thing happened on the last 356 we had. Took out the starter, took it to the shop and bam!!! Hot start fixed
SteveL
Huge chevy guy
Hawthorne ca
Where did the starter come from? Back in the early days of having my 72 I put one of those cheap starters on from eurozone or oriellys. It went out within a year so I got the replacement. After 3 or 4 of em I realized I was getting about I months out of a starter. A friend told me pay the extra couple bucks and get one from napa. Problem solved. Since then I've avoided the cheap chain stores and get most of my parts from napa or summit. Now with napa you do have to ask for the better line of parts since they started carrying a cheaper line of the Chinese crap to compete with the big chain stores
