So I did a ford disc brake swap on my '74 and since I did the swap my rotors are getting way top hot after short drives - water will sizzle right off of them. Otherwise the brakes don't seem to drag and work outstandingly well. I was Hoping a few hard stops would fix the issue it doesn't seem to be getting any better.
D44 with knuckles and holders off a '79 F150. New rotors, etc. with astro hydroboost
The only warmth in the hubs is coming from the rotors - so it's not the bearings being too tight. Even so I checked the install and they are perfectly spec'd.
I have double checked the HB pushrod - length is perfect and it isn't pushing on the MC, etc.
I removed the calipers and sanded paint of all mating surfaces. The key fits fine - it just needs to be lightly tapped with a hammer into place.
I can spin both wheels fairly freely when jacked up - when I spin the wheel they'll do about a full rotation before stopping. I understand this small contact between pads and rotors is to be expected.
I've jacked the bronco up And spun the wheels both turned and with the engine running - no difference.
I've only just gotten the bronco on the road in the last month - I've only put about 50-60 miles on it.
But should the rotors still get frying pan hot????
