Too much camber
KUBOTA OWNER
I was wondering if any one would be able to help me with a new problem that seems to have come up. I have a 69 stock bronco with no mod's. I do not drive it everyday. I have notice a pull to the right and excessive outside
tread wear. -- Just by looking I can see that there is a lot of positive camber
on the right side. --- as much as 1/2 inch from top to bottom.
--jacked it up and can't find any play in the king pin or wheel bearing.
The "C" bushing are about shot, but still hold the axle tight. --- from looking at the suspension set up I can't see why i have so much +camber.
Do you think the "c" bushing would cause this? Or what should i look for?
---Thanks
Hozr
Rogue Valley, OR
C-bushing would tilt the whole axle. It's got to be the kingpin/balljoint, bent spindle, or someone added a camber shim behind the spindle.
How worn are the tires? Really ineven tread wear could throw it off as well.
spap
Broncos tended to come with a lot of positive camber the C bushing effects the castor not the camber. There two ways to fix it camber shims that were mentioned that go behind the spindle and adjustable ball joints. I have the same issues with my 77 just haven't fixed it yet. . As for the shims there are two types a 6 stud and a 5 stud for the Dana 44, I think you would have the 6 stud which is good since jeeps used those also. 76_77 have 5 stud pinions which are kinda hard to find
K
KUBOTA OWNER
Yea it hard for me to make any sense of this, Never hit any large rocks or bent any suspension parts. I have had the king pin bearing apart years ago and they seem to be a non-wear item? --no slop when jacked up and pulling out on top and botton of wheel.
I think this is a dana 30 set up. ---Question? What would you start pulling apart first?
--should i try to remove the upper king pin, or would there have been play when trying to move the wheel and out? --GETTING A LITTLE TO OLD FOR THIS MUCH BRONCO FUN,
--HA, HA. ---THANKS any help is appreciated.
Justafordguy
It sure sounds like a kink pin problem but it's odd that there is no play. Maybe you should stop by an alignment shop and have them see what the castor really is. Maybe it looks worse than it really is because of the tire wear?
K
KUBOTA OWNER
As crude as it sounds, I parked on a level spot and the front bumper looks good with a carpenters level. Then if you stand back 10' and look at the front
wheels you can see that the pass side is leaning out. -- if I put the level on the wheel it will be at least 1/2" out on the top. the drivers side is about perfect level. ---strange that it steers and drives ok, other that a pull to the right. --- no power steeering and pass car 235/75r15 tires.---there is no binding or hard spots turning or klunking on bumps. --- the vehice is kept up at a cabin in the woods 75 miles north of here which makes it hard to work on. I would like to have some plan of what I may find before tearing it apart and then finding out that I should have loaded on a trailer and brought it home where I have more tools and a garage. --Thanks for any input.
Hozr
Rogue Valley, OR
See if you can narrow it down to the axle housing or ouside the knuckles.
Put it on jackstands and pull off the front wheels. Check the spindles and hubs/rotors for square. Measure the flat sides of the knuckles as well. Measure everything before you tear into it and narrow down where the trouble starts.
