Top loader 4speed clutch
Same as the stock 3-speed.
164 tooth, 50 oz-in balance factor flywheel. Bolt pattern to match the pressure plate.
11" truck clutch, not the little mustang clutch.
nvrstuk
PNW
go Organic disc, not ceramic. The toploader gearing is high enough that you will want the clutch to be able to slip without "instant engagement" of ceramic.- or at least it trying to engage quickly.
I went thru 3 different ceramic clutches as I wanted a strong disc with a ton of holding power and was talked into it. I switched to a organic disc and it worked perfect.
KempDaytona
KempDaytona
Knoxville
I've been told to buy a clutch for an f100 and to avoid a clutch for a mustang. But my motor and transmission came out of a mustang.. I'm confused
What did your bell housing come out of? You use the clutch for the engine and bell housing, not for the transmission and donor vehicle when it comes right down to it.
There are exceptions to that rule, but if you know the particulars you will know which clutch.
The reason you would NOT want a Mustang clutch is that they are usually the smaller diameter version compared to a truck clutch, so would be less than desirable in a truck application such as your Bronco.
As was said, as long as you have the engine you state, and as long as it's the Bronco or other truck bell housing, you MUST use the larger diameter truck flywheel and clutch components. If you don't your starter will never be able to touch the smaller ring gear of the Mustang clutch.
That's for the flywheel with ring-gear, and the associated clutch cover/pressure plate. Those go with the engine and bell housing.
The only things that would matter with the transmission are the clutch disc/plate, the throwout bearing, and the pilot bearing. And in our case, all three are very common among Ford products.
So if your top-loader trans has the same input shaft size and spline count as a Bronco, you use a Bronco clutch plate.
If it has the same diameter bearing retainer and throwout bearing "snout" as a Bronco trans, you use the Bronco throwout bearing.
If it has the same nose size as a Bronco transmission, you use a Bronco pilot bearing.
I call them "Bronco" parts, but as mentioned the same parts are common among many, many Ford products.
They're not the only ones Ford used, but they are very common nevertheless.
One of the few times Ford did that, fortunately for us at least.
So what parts are you running? And what did the transmission come out of? If it's a close-ratio 4-speed out of a Boss 429 for example, you're probably out of luck.
If it's a wide-ratio out of a garden variety Mustang with a Windsor family engine however, there's a very good chance it'll all mate up just nicely.
nvrstuk
PNW
Everything Paul said.
I ran a wide ratio top loader for years from behind a sbf (which is what you want) and it uses all Bronco clutch parts.
They are a fun street tranny!!! :) Can't remember how many 28 spline axles I grenaded when I had mine in!! ;)
What Paul said x2. He knows his stuff.
You say the motor and transmission out of a mustang, but what bellhousing are you running? Is that mustang as well? (aluminum is a mustang) If so you are going to use a mustang clutch for the vintage mustang. Not as well matched to the Bronco.
Do you have the Bronco bellhousing, that holds a Bronco sized (11" truck) clutch. Bronco bellhousing is cast iron.
I don't know if they made cast iron mustang bellhousings, I think they did. Not a mustang expert, just general knowledge of them.
Good point. If in doubt, try to find an engineering number on the bell housing that would indicate a truck or car family it was designed for.
For example a cast iron C6TZ-somethingorother, or a D1TZ-somethingorother would be for a Bronco. An aluminum C4AE-somethingorother or F4AE-somethingorother would likely be the Mustang. Numbers are examples only, and may not represent reality.
And a mid-nineties Mustang bell housing probably had a hydraulic clutch? Maybe? Not sure about that.
Paul, the '90s mustangs were T5 transmissions. Those had there own unique bellhousing that clocked the transmission. Transmission side bolt pattern was a bit different as well. And those clutches were cable activated. They were the small flywheel and small clutch, although the clutch was upgraded from the '80s as they went from 10" to 10.4" because they had issues with the 10" not taking the power of the 5.0 back then. The 10.4 was the biggest they could put into the little T5 bellhousing.
The last of the top loader era of normal 4-speeds was the early 80s. Still a cable clutch as were all the fox body mustangs. But that was always the 10" clutch as that era still had lame engines that didn't have enough power to hurt themselves. Even the high output engines were still a 2-barrel carburator and a cam from the marine engine line.
nvrstuk
PNW
Aaah, the vulnerable T5... I remember a few guys trying the T5's in their Broncos back then. I was looking soooo hard for an OD trans that I talked to these guys, all their parts swapping and then the inevitable early death of their T5. :(
Make sure you get the Bronco/truck clutch setup as the torque loads we put clutches thru with big tires against big rocks and all 4 tires being locked creates huge torque loads compared to any stock setup, let alone a Mustang.
Thanks for the reminder. Forgot all about the old cable clutch releases. Weren't the plastic "quadrants" (were they called?) an Achilles heel in those years too?
I seem to remember people selling kits that replaced some plastic pivot points with aluminum or something like that.
fordfan
My "Rattler" Bronco is a Cleveland and a WR toploader. It's a really fun Bronco to drive! The clutch is not ceramic like nvrstuk suggested.
The pressure plate and the clutch is a McLeod unit if my memory is correct..
I went back and found some pics..
nvrstuk
PNW
I'll bet that WR toploader is a kick in the backside with the Cleveland!! :)
I didn't suggest ceramic, I suggested organic. I will look back and correct my post if that's what I typed by mistake.
Ceramic is too positive of engagement when trying to slip a clutch for wheeling.
fordfan
Hey nvrstuk.. I was agreeing with you that a non ceramic clutch was the way to go. Sorry that I worded it wrong.. Oops... LOL... Yes. The Cleveland is meant for a toploader!:giggle:
nvrstuk
PNW
We're good!! :) I'd love to go for a ride in yours!! Perfect combo!! :)
KempDaytona
KempDaytona
Knoxville
But the motor come out of a mustang. Does that matter? I'm new to a manual transmission build.
Nothing special about a mustang engine. When that block was born it didn't know it would be in a mustang, Could also have been installed in a truck or a van, or a boat, or...
Quick & Dirty
Again, what bellhousing did you use? The small bellhousing was used in compact cars, like the Mustang, for more foot room. Used with the 157 tooth flywheel and 10" clutch disk. The big bellhousing was used in full size cars and trucks (including Bronco) with a 164 tooth flywheel and 11" clutch. If you use a Mustang 157 tooth flywheel and installed a Bronco 164 tooth bellhousing, you'll have starter issues.
There are also 2 different pressure plate bolt patterns, the early Borg and Beck style and the later diaphragm style.
