torque converter bolts flush with flexplate
IH8JEEP
We are stuck! We have a mid 80s 302 and just installed a 50oz flexplate to bolt to the c4. The flexplate is 164 tooth has 10.5" converter holes(its even drilled for a couple size converters) PRW pn:1830212. Got the motor back in and lined up the flex plate and the torque converter bolts are flush with the flex plate holes. Anybody have any ideas before we pull the motor again.
pcf_mark
I am assuming the engine and trans are bolted up right? Is the flexplate on backwards? I think it has an offset but you can see it visually if it does. Most people are the other way and can't get the engine and trans to fit up tight.
Viperwolf1
electron whisperer
I question the 10.5" converter. They are not available for 164 tooth flywheels any more. Which probably means it's a 157 tooth type converter, which means it's actually shorter than the correct one, which means you probably don't have it seated all the way into the trans.
73azbronco
did you feel the double clunk/double step as the shaft was inserted into the TC?
IH8JEEP
IH8JEEP
Thanks for the input guys. I told the boy lets give it a rest have a cold one. We took a pair of pliers grabed the torque converter drain bolt and the darn thing pulled right into place.... DUHHHHHH.
