Torque specs
Brake backing plate presumably? Should be the same as the spindle bolts, correct?
Unfortunately my Chilton's bronco book does not list them, or at least I am blind and can't find them. The Haynes book does but it's 73 and later so only Dana 44.
However, in that case they do give a range of torques as follows:
1/2 x 13 = 55-70 lbs
7/16 x 14 = 30-50 lbs
1/2 x 20 = 55-75 lbs
However these books are known for typos, so wait for someone with a Ford book to confirm those values. Especially if they have something more Dana 30 specific. Do you know what size your bolts are?
An old article from a 2004 issue of Petersons for wheeling off-road lists Dana 44 and GM 10 V spindle backing plate bolts at 65 pounds.
Hence the need for checking size and back up confirmation.
