TPD Classics "Customline" Molded ABS Rear Quarter Panel Set for 1966-1977 Ford Bronco
tpdhifi
Classic Style, Modern Fidelity
Broken Arrow, Oklahoma
These quarters, along with our matching door panels are part of the flagship first products in the CUSTOMLINE family. Available in three distinct styles, you are sure to find a variation that looks just right in your interior. The vertical pleat and diamond pattern have a refined and understated look that is ready to install, and the custom upholstery-ready version comes with an hardboard insert to make upholstering your quarters to match the rest of your interior a breeze! These quarters are not simply mirrored images of one another...each side is designed specifically for the Bronco's geometry, leaving no unsightly gaps. The low profile design of these panels makes them flexible and easy to fit behind roll cages. They are compatible with both hard and soft top rigs.
https://tpdhifi.com/collections/1st...r-quarter-panel-set-for-1968-1977-ford-bronco
Features​
  • Fits 66-77 Bronco (soft top and hard top)
  • Molded from durable, all-weather ABS plastic
  • Low profile enough to fit behind roll bars
  • Easy to install for most top configurations
  • Fits single or dual fuel tank Broncos
Designs​
Customline rear quarter panels are available in three versatile styles:
  • Vertical Pleat – A period-inspired design that echoes classic Bronco interiors and traditional restoration builds.
  • Diamond Pattern – A modern, structured design that adds visual interest without overpowering the interior.
  • Custom Upholstery-Ready - Includes “Upholstery-Ready” Insert - customize your door panels to match your interior theme.
Tobtech
do these have provisions for a speaker? i'm seeing that "grille" section
For the 4188-3 we are working on a speaker kit that will include a thicker insert with a speaker mount in the rear section of the panel that can be upholstered. It will be available by mid Feb. We have found that the space in the rear area is a little bigger with less obstructions and will allow more speaker options. The Bronco is so short there isn't much advantage mounting the speaker up front. The area in the front that looks like a grill is just a faux grill but we could possibly turn it into a functional grill later. If anyone has any questions, don't hesiiate to call me. I will put my number below. I am the tech support guy for TPD.
Also, if anyone is in the Tulsa, OK area. We will have these in our Bronco in the booth at the Starbird Rod and Custom show on Fed 20-22. If you can make it, stop by the booth and check them out. We would love to meet you.
Toby
918-992-6292
duffymahoney
Super cool! Any plans for more stock/ classic styled options? My next change to my bronco will be to make it appear more stock and more away from the restomod look.
tpdhifi
tpdhifi
Here are the new Rear Quarter Panels with Speakers that you guys asked for:
https://tpdhifi.com/collections/1st...-panel-set-for-1966-1977-bronco-with-speakers
Tobtech
nice! bummer, i'm seeing they don't fit a 77 now. was looking forward to an option for me
That looks like just a typo. Top of the flyer says 66-77. Give me a shout at 918-992-6292 to place your order. Depending on stock, these ship same day in some cases but worst case 3-days. Thanks for looking. Toby Lewis Audio Manager
