Trail lights AND under dash LED lights
Banjer Picker
Looking to mount some lights up inside the wheel wells to throw light down on the trail around the truck on a night run. Should I run the positive wire straight off the battery? Do I need a fuse between power source and switch?
Would also like to run LEDs under the dash (that I can turn on/off with truck off). I've heard LEDs draw far less power and have different requirements. Can anyone point me towards previous threads on these?
Thanks!!
garberz
Bronco Influencer
Conejo Valley, Ca.
I have five lights underneath that I use on night runs. They're nothing fancy, just tractor flood lights. They draw quite a few amps each, so they are on their own circuit with a relay. Anything you pull off the battery should be fused. If your running multiple non-LED lights for this, I would use a relay. LED's draw a fraction of power compared to halogens. They're great for interior lighting.
Mark
Pat'sBronco
Murfreesboro, TN
My son bought a led bed light kit from LMC. He used 3 under his dash and its perfect! I will be using the other 3 under my Bronco dash. That kit comes with the switch by the way.
NYLES
Banjer I think im gonna put 2 led floodlights on the frame behind the door and hope they put enough light out the front sides......led lights run far less amps than regular stuff the 2 on the front of my duck boat draw 1.2 amps.....but they expensive.
68rockcrawler
I got some stick on LEDs from Autozone that are about 6" long that I stuck under my dash and in my glove compartment powered through the dome light fuse and they work great and were pretty. Heap.
JohnJohn
Richmond
Here are two pics of the LED's under my trail rig.
