g-money
Can I use rubber fuel line for the tranny cooler lines or does it need to be steel with compression fittings? Are the tranny cooler line under any pressure?
Thanks<
Galen
Thanks<
Galen
pinenuts said:Hotwheels...Wouldn't the pressure be the same everywhere in the cooler loop? It is hard to believe there is much pessure drop in the radiator.
HotWheels said:I'm using Earl's Super Sport hose and barbed fittings. I know that on the upper end the c4 works at about 240psi; so when they said dont use regular rubber hose they were spot-on. I am running the hoses from tranny-radiator-in-line-cooler-to tranny.
hth
Mick
72bronco said:I've been running rubber tranny cooler lines for years with no problems.
Jeepster said:I just wrap them around the headers a couple of times. %)
72bronco said:I have full-length headers and am able to route the tranny lines away from them with no problems. Mine just run along the frame rail to a tranny cooler mounted in front of the radiator.
Broncobowsher said:When I did the automatic conversion I was running long tube headers. I found it easier to just route the cooler lines up the back of the transmission (following the dipstick) and across the top of the intake. Those were steel and rubber ran from the top of the intake to the coolers in the rad and grill.
