fatboy4211
with summer putting a laser dot on my forehead. which would be better to do...a derale trans oil cooler or a derale 8" electric fan to assist the stock fan.
i have vintage air so im limited on space for electric fan to supplement the stock fan and shroud system. radiator is a 4 core. it currently runs at 190 degrees with the ac blowing 54 degree air.
i was told that the tranny itself can be a major player in raising the heat level and keeping the radiator at a steady high temp.
if so which would you do. i have a 105amp alternator so im hoping it will be enuff power to run it all.
thanks for your input
