tranny dropping tool
jerrybromley
I have read in many post in this forum what a pain in the *ss it is to take out and put in trannies. So I thought I would show some photos of a rig I built out of a Harbor Freight hydraulic table and some scrap metal. The carts handle removes easily for sliding under the Bronco.
With this set-up I had to have 30" of clearance under the Bronco and after lowering it the tranny rolled right out. I haven't used it yet to put the tranny back in, but all the angles should be right to slide right in (I hope;D)
Madgyver
Bronco Madman
i built a trans dolly that locates onto a floor jack. it has a tilt feature also. Makes easy work of dropping the transmission.
Jdgephar
Very nice...I did the same, but manual trans and wood blocks on the same hyd table. Worked great!
Sent from my SM-G981U using Tapatalk
blubuckaroo
Grease Monkey
Ridgefield WA
Lifting a tranny is one thing. The transfer case has been more difficult for me. It's heavy and oblong. It's difficult to keep it vertical.
I've actually dropped mine on the floor twice.
bigmuddy
Marthasville Missouri
I like the idea, I have a HF tranny jack but the l brackets to hold the tranny on to it are rinky dink.
I may try this to see if I can install the new 4r70w and atlas at one time.
bigmuddy
Is this the 500lb or 1000lb model.
The 1000lb seems to have a higher lift capacity.
mrdrnac
Here is what I did for the Transfer Case, made a wooden cradle to hold it upright and then attached that to the top platform of the transmission jack.. Going to try a similar wood cradle for the trans....when I need to do it. Being creative is the key!
nvrstuk
PNW
Jerry, that is a cool looking setup you built. Nice!
I didn't use a tranny jack till my ZF/203 combo... I am not a big guy but a D20 weighs 80#'s soaking wet. Hoist it up there and slide it in. A 3 spd doesn't even weigh that much. 6 different tranny's and 4 different doubler combo's not including 4 grenaded D20's so it's pretty much my workout. :)
I did buy a HF jack for my 6r80 that weighs in at 215#'s but hoisted the Atlas up by hand since it's easier to clock it when its not on a jack. I ripped my shoulder up really bad 1 1/2yrs back and there's nothing like not using your muscles for over a year and then realizing you don't have ANY left! lol
The key is to get it on your chest so you can raise it straight up. If it gets off center I wish ya luck.
Ratchet straps (2 min) with a angle iron bolted to the "saddle or plate" as a stop on your trans jack plate to keep it from sliding off really makes a difference. If it wiggles at all when you are testing it then you will probably have a disaster when it's 24" off the ground. lol
mrdrnac
AT 71 and still turning wrenches on my Bronco for a Hobby, I try and use ALL the power tools I have, talk about no muscles left! Hell, I can't even post pictures right side up!
nvrstuk
PNW
Mrdnrc...I'm catching up fast!! Right behind ya. :)
jerrybromley
jerrybromley
Thanks Everyone , I'm about 5 years from Mrdnrc , the only way I can see to keep pullin wrenches is to find easier ways to do it ;D and trannies are not easy no mater what you do
bigmuddy
Jerry, while I’m sure both work, did you use the 500 or the 1000? The 1000lb weight capacity also has a higher reach capacity.
Tia
Rustytruck
that scissor lift table has been one of my better buys. its very close to my tailgate height for my Toyota pick-up and easy engine lift for my vw sand rail and vw beetle. great for up lifting rock sliders and bumpers. all around great and useful buy. at 62 my lifting days are over and holding anything up is now next to impossible. I have the 500 lb model. should have bought one 30 years ago as I always pretty much work alone.
jerrybromley
jerrybromley
Tia , The table I bought was the 500 lb model.
I put my tranny and transfer case in yesterday. Wow this is ALOT easier !;D
When I built this thing, I took measurements on the height of each jack stand the Bronco was on. Then ran the table up tight to the tranny and transfer case and built my attachments to fit in the installed position and tack welded it together.
I had to lift the Bronco to roll the tranny and transfer case out.
On installation I returned the Bronco to the same height as I originally had on the jack stands . This put truck and tranny setup at the same angle as I took it out. Low and behold the tranny slid right into place easily all by my self :cool:
