Tranny swap
MikeCon
Any ideas on what going from the c4 to an OD would cost on my stock 1973 with 302? I am pretty sure gears are stock.not really too concerned about fuel economy.. Going to be a driver so noise and comfort is more important.
About $2k for starters, with a LOT of variables.
Need to know the gearing and tire size. Even though you say non-stock, still doesn't mean it is correct with the overdrive.
MikeCon
MikeCon
Think I'll keep the c4.maybe a shift kit. Its going in for a rebuild.
bmbm
AOD swap
Lots of good info at this link. Depending on your luck at sourcing used parts and how much work you can do it might not be too expensive. I can tell you that od really changes the driving experience. Relaxed highway cruising is so pleasant. With your stock looking tire size and probable 3:50 gears you may be good to go.
https://classicbroncos.com/tech/aod-3-speed-automatic-transmission-guide
Don't do a shift kit. The Bronco C4 has a factory shift kit already in it. Putting an aftermarket one in (even a mild one) makes them overly aggressive and they chirp tires and overall suck. Many rebuilders insist on putting one in, they are not doing you any favors. Stock is good.
Hazegray
I've had my AOD since 2006 with a 351W, 4.11 gears and 33" tires. Does very well on highway, but like mentioned before, gearing is going to play a major role. If I had to do it over again, I would keep the C4 unless you are going to be driving on the highway constantly. Losts of money invested for OD when the reality is I don't drive as much on the highway as initially planned...%)
sprdv1
REBEL
I've heard of good / bad experiences w/them
