- May 18, 2004
- 5,283
and if your transmission is sucking up fluid of the proper temperature from the pan, then all the friction surfaces and gears should be happy. What comes out of the transmission isn't really important.
So by this reasoning I can superheat my fluid until it is nice an brown and smells like english muffin that's been in the toaster for 20 minutes, but as long as I cool it down before it goes back into the pan all is good??:?
At what point does the fluid become "burnt" and loses its desireable properties? I've seen more than a couple charts in the past that say when fluid reaches a certain temp its properties are shot and must be replaced. I really can not see how the fluids properties that get destoyed by heat would "care" if it got hot before or after the pan?
Peronally I learned how my various temps would react to hard climbs and how the different sender locations related to each other and I never once went off in a "panic". Maybe that's just me being cool under pressure ?
