Tranny Temp Location
Where to mount transmission temp sensor?
  • Pan
    Votes: 14 56.0%
  • Line into cooler
    Votes: 9 36.0%
  • Line out of cooler
    Votes: 2 8.0%
  • Total voters
    25
Muddypony
Where do you feel the transmission temperature sensor is most effective? There seems to be some debate over this.
Bronchole
Chatsworth, Ca (LA)
I see the logic of reading the line out, you get fast response to what is going on in the trans but I gotta vote for the pan.
I think this really revolves around what is it that you want to see when you are monitoring the trans temp? Do you what to know what you are doing to the fluid? Then the output it is. Personally, I want to know if I am abusing the trans itself. Pulling a long hill or just being a bit too hard on it in the rocks. Overall, if I see the temp go up in to the danger zone I try to back off a bit and keep the temp in mind. If I exposed it to danger level temps for a prolonged time I move up the timing for my next fluid change.
As far as detecting problems with the trans, if I have a cooler problem, that will result in the pan temp running hot always. If I have a internal trans problem that will result in the pan temp running hot always.
I really don't see any use in monitoring the temp coming off of the cooler. The only thing you learn there is if your cooler is capable of cooling the fluid. The better your cooler is the less capability you have to see the output temp and the trans temp.
The primary thing to keep in mind no matter where you monitor the temp, do freak out on the temps you see. You need to get familliar with what the normal temps are for particular operating conditions and then be aware of when it is not in the normal range.
Dan
BUCKETOBOLTS
Salisbury, NC
Oil returning to the tranny lubes the rear bearing and dumps into the pan for circulation. I've had good results from mounting in the line. Sometimes it is hard to get a fitting in the sheet metal pan to seal. A good aftermarket aluminum pan may lend itself better to mount a sender since it will have more beef to drill and tap.
Here is the manifold I have used in the past:
www.autometer.com
av bronco
Palmdale CA
If you put it to the out line from trans to cooler you will get some crazy readings(thats where mine is now) I think the temp sending unit was made for pan temps.
Muddypony
Muddypony
Now I'm totally confused. I can see benefits to the pan and oil out line.
VT_Don
this is common knowlege
Talk about clueless hacks. Do some homework.
Viperwolf1
electron whisperer
When a C4 pumps fluid it picks it up from the pan and sends it to the converter where it builds heat. The lower the engine rpm, the more the converter slips and the more heat that is generated. From the converter only some of the fluid goes through the cooler circuit (probably less than 1/4 from the size of the cooler passages). The rest goes to the servos, front bushings and the two clutches which also build heat. From there the fluid drops back into the pan. From the cooler return the fluid lubes the rear bushing and the one-way clutch. Then that fluid drops into the pan.
Now if you're mostly interested in how hot the converter is getting measure the temp at the cooler pressure port. I've done it and it's temp was never below 200 degrees and got as high as 270 degrees (190 in the pan at the time) depending on the load and engine rpm.
If you're interested in how well your cooler is working measure at the cooler return line. It will be lower than the pressure temp but will still vary greatly along with rpm and load as you put the converter into and out of it's efficiency range.
If you're interested in the general trans operating temp as a whole (after accounting for heat generated by the pump, converter, clutches, bands and bushings) put the sensor in the pan. It should stay relatively constant unless you're generating more heat than your cooler can shed. At that point you either need more cooler or you have a problem inside the trans.
76 bronco J
>>>>> if your going to put the sender fitting on a sheet metal pan it should be tig welded in(tig is less likely to warp the metal) .... that's what I did on my engine oil pan for my oil preluber & wouldn't even consider some bolt in fitting with a gasket & a nut on the inside that could come loose ..... as for the tranny sender mines in the pan.........
