Tranny Trouble
U13
Mammoth Lakes, CA
Hi Everyone!
Just swapped-out my old 351 for a 5.0 out of an '01 Mountaineer ;D. The old C4 buttoned-up just fine, but after driving around for a day or so, tranny fluid started pouring out. We pull the tranny and found a small dent in the seal, so it was replaced and ran just great... For awhile.
Took it to Bronco Daze, ran it for 4-5 hours and tranny fluid started pouring out again. Any suggestions on what might be causing this? I find it hard to believe we trashed two seals.
Thanks!
U13
75junebug
NW Houston Tx
When doing the swap, did you use the Torque converter and flex plate from the 5.0, or did you use the orig flexplate and torque converter. I had a hard time finding a flexplate for a 50oz balanced engine(post 80 302 and all 5.0) that would bolt up to the C4 torque converter. The sealing surfaces on the 5.0 TC are a bit different than the non locking C4 TC and could damage the seal.
If you went with the flexplate from the 351, it is balanced at 28oz, and the vibration could cause the seal to leak...maybe???
Or maybe it was just not locked in properly before installation and the pump seal surface is damaged(This if the correct flexplate and TC is used).
Viperwolf1
electron whisperer
Fluid level may be too high. It should only reach the hot mark on the dipstick when it is hot. That would be after several miles of high speed driving. It's very common for people to over-fill the C4 because they only check the level when cold. It will puke if its over-filled.
Another possibility is its overheating. How does the fluid look and smell?
NicksTrix
is the fluid coming out of the front seal/bellhousing area or rear vent?
U
U13
Mammoth Lakes, CA
Hi Junebug! Thanks for the reply. I can't remember which flexplate we used, but we'll definitely check it out!! U13
U
U13
Mammoth Lakes, CA
Hi Viperwolf! We checked the fluid level constantly, and it was at the full mark (no foaming). Fluid's the proper color and smells fine (no burning).
Viperwolf1
electron whisperer
Only 3 possible leaks at the front, converter seal, converter drain plug, pump gasket. Check the drain plug. If the converter snout is chewed up it will eat seals.
BwoncoHowie
C-4 Wizard
Hi NicksTrix! Thanks for the reply!! Definitely coming from the front seal/bellhousing.
Check the converter Hub for a seal groove, if it's too deep a new seal wont help.
Also if you have too much clearance between the converter hub and the pump bushing, IE. the pump bushing is worn excessively, the pump pressure will leak faster than the oil return hole can accomodate the volume, and the excess volume/pressure will be forced beyond the seal's ability to contain the oil and even a new seal will fail at this point.
Usually when this happens the inner pump gear is chewing against the crescent and a rebuilt pump is in order, or at least replace the gears when the pump is repaired.
A C-6 pump bushing will fit in a C-4 pump and will last longer than a C-4 pump bushing, when you are replacing that component.
~BH~
