southbaybronco
- Jan 27, 2009
- 193
I just had the WH twin stick installed and parts replaced in the D20 while the trans was being rebuilt and everything was out from the bronco. I took it for a test drive and went through the transfer case to make sure it all worked. While doing so on the street in 4H there is a gear noise. The hubs were not locked and i was driving down a straight road. In 2H it's quiet as can be. I honestly don't remember gear noise in 4wd before but never engaged it on the street. It was always in the dirt and probably couldn't hear it anyway. Do you hear gear noise when you're in 4wd coming from the transfer case? Not sure if the teeth are different and i don't want to say anything until i can rule out that it's not right.
Thank you,
Kyle
Thank you,
Kyle
