Transfer case grinding in 4 high
G
Guest
Guest
hard to say what it is but check your oil for metal your bearings may need to be replaced or there may be to much end play on your output shafts which means bearing are in need of replacement or the shift fork could be out of wack and the sliding gear may be grinding on it. good luck
Newt
You better find out what the problem is. The longer you drive it & let it grind. The more $$$$$$$$$$ it'll cost to repair.
