pipeline010
- Nov 15, 2017
- 618
First of all, big shout out to the guys at "Project Breakhorse" for finally posting a fairly complete rebuild video on the dana 20-J version:
https://www.youtube.com/watch?v=Lmos-vvofEk&t=476s
Now to me...my rear driveshaft has been clunky lately. Thumped Sunday when I quick let off the throttle and didn't when gradual let-off, so I figured a u-joint was toast. Google 'failed ujoints' and you'll see 99% of them better then what I just removed from my truck. Zero needle bearings on two opposing sides, cracked caps, obscenely worn heads. Never replaced this one in my time of owning, so whatever.
I replaced the rear most joint last spring, this time it's the second in the series not counting the CV. The first is still from PO or beyond.
Drop the shaft and test the main output nut on the t-case...it's a smidgen loose, but I was hoping for way way more since it's been spitting oil the last few months. It's def torqued to spec or close altho I didn't use torque wrench, just a long ass breaker.
Downside is...assuming the yoke is a clock face I've got about 20 minutes of CRUNCHY free play. Doesn't SOUND crunchy, just kinda FEELS crunchy. Not smooth.
Question 1 - I'm looking at replacing the bearings in the output shaft now ya? Based on that description? Not just seal or could it still be seal? Additional note: the speedo reads about 5-6 miles BELOW actual (confirmed by my cop body that haunts the bridge). Related?
Additional Additional Note: There doesn't appear to be any play beyond loose SPIN (no up down side to side).
Truck will be rolling no matter what for 3 more days to/fro work, so I'm pretty happy the one old ujoint is still on the shaft as the weakest link to the system.
More Questions:
If I do need to replace the bearings on the output shaft (fore to the yoke) I don't plan to take the whole tcase off the truck, just the output assembly. 4-5 bolts + speedo cable but any tricks/tips to getting that guy off WITHOUT dumping those needle bearings? They fall in and I need to open the whole case....REALLY don't wanna do that as this alone is on the extreme end of my previous knowledge.
Last question:
I'll be cooking my bearings to slip them on the shaft. Yes cooking. What's a good oven temperature to get them good and crispy golden delicious? And by that I mean proper to slide down the shaft.
Any other tips?
Thanks team!
More Questions:
Last question:
Any other tips?
Thanks team!
