Dyehard
- Feb 17, 2010
- 231
PO broke three of the bolts off on passenger side of the frame mounted bracket that attaches the crossmember to the frame. It only had one bolt holding it up. I have tried everything I know to remove the broken bolts but I can't get them out. I have soaked them in PB Blaster, I have heated them, and my bolt extractors are on the verge of breaking when I try to use them. I am thinking about drilling out the bolts but if I do that I will have to drill out the threaded sleeve that is attached inside the frame. Will nutserts be strong enough to use at this location? Any other suggestions? Any help will be greatly appreciated.
