Transmission input needed
cool66bronco
Hatfield PA
I am looking at the a NV3550 out of a 2003 jeep wrangler. my motor is the out of a 91 mustang 5.0 will this match up pretty well with minimal mod's? I read on the site that is one of the best 5 speeds for the EB.
Jerry
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Takes a $1,000 adapter kit to install in a Bronco. Need to mod the bellhousing, install a different clutch disc, move the shifter hole in the floor, use the cross member that comes with the kit, etc.
All included in the kit, but I would say it's a pretty big mod rather than a bolt in.
C
cool66bronco
Hatfield PA
Ok that is not exactly minimal modifications but if it is was is required so be it.
SO if I were to go with the ZX 5 speed how many mod's and how hard? I see one adapter kit needed, what else?
getting my motor ready for heads and intake and trying to get a jump on the next think the trans while I am doing that.
thanks Jerry
thegreatjustino
Stockton, CA
Do you mean the ZF five speed? That will bolt right to your engine (transmission has an integral bell housing).
However, it will require you to swap from a clutch with a mechanical linkage to one with a hydraulic activation. Need to install the master and slave cylinders as well as lines to move the fluid. Again, a decent amount of work. Trying to put just about anything modern in a classic Bronco isn't going to be a simple bolt in.
C
cool66bronco
Hatfield PA
yes i will be replacing the mechanical with hydraulic clutch. I have a body lift of two inches for clearance and hole in hump for shifter. the adapter kit for 4x4. Do I need to modify the trans in anyway and what about the drive shaft? will i need a replacement longer or shorter?
thanks jerry
OH yes I meant ZF 5 speed!!!!
C
cool66bronco
Hatfield PA
the ZF's i have looked at are for 4x4. i can get a reman unit for 1195 + shipping. add the adapter kit for around 300, the hydraulic parts and clutch pressure plate 3-400 and still not sure about drive shafts.
I heard the whole conversion can be bought from on e of the vendors here for around 2200. what make sense?
I am looking for a cruiser with a little snap and will be appealing to most people.
I do thank you for your input. I have 5 cousin living in stockton. asperigus (sp) capital of the country. Jerry
thegreatjustino
Stockton, CA
The ZF is a large truck transmission and shifts like a large truck transmission. If you're looking for a fun more peppy type driving experience, the NV3550 or the AX-15 would be the better choices.
Tedster100
Chairman of the Bored
You're going to need custom mounts for the t-case anyhow, you'd be better off to get a used NP205. Bolts right up to the ZF, you just have to cut a notch in the flange. You should be able to find a NP205 for $300 instead of spending it on a adapter to install the lighter duty Dana 20. Then you have a heavy t-case to match your heavy duty ZF.
Also, unless you are sending them an old ZF in chances are you need to add $300 to that ZF price, they always want a core. I just did this conversion, $400 for a junkyard ZF, $120 for the ZF cross member, I made my own mount for the NP205 (because it needs supported), around $25 for the master cylinder push rod conversion from BC Broncos. I got the master from the donor with the trans and bought a new slave. I also put a Centerforce Dual Friction clutch & pressure plate in with a new flywheel. I probably have about $1200 total in it, new clutch and all. There are several good swap articles on here.
bmbm
trans swap
Have you considered the M50 five speed? They should be available used for a reasonable cost in places like picnpul as they were in many 90's f150. Just need one adapter instead of two. It's probably quite a bit of work but any swap would be.
