Rox Crusher
- Dec 13, 2008
- 2,772
Howdy guys,
As we learned a few things specific to 76/77 model Bronco, I thought I would share results of my TieRod Over conversion using Roughstuff TieRod End components in combination with knuckles off of a 78/79 Bronco.
The tie rod attachment points on the 78/79 knuckle are about 1" lower than the stock knuckles used on 76/77 Broncos. So in theory, the 76/77 knuckles would be better in terms of achieving maximum trail clearance for steering linkage.
Unfortunately, the attachment points on 76/77 are about 1" closer to the wheels preventing use of any of the heavier duty steering linkage components available which is why I elected to use the 78/79 knuckles.
On to the good stuff, since the 76/77 Bronco came stock with a longer track bar bracket, you don't have to use a drop pitman arm or an axle riser bracket to achieve nearly perfect geometry between trac bar and drag link. Mine ended up being within 1 degree of each other.
I will post pics later when it gets lighter out.
