I went with the EZ-Wire harness it's like 140 bucks and man I am glad I did. So much easier than trying to figure out 40 year old wires that where never labeled.
I think if I had it to do over again I'd do like lowbush. My wiring wasn't bad, but the comfort of having all new wire and not relying on old connectors that could go out at any time, it would be worth it.
I pulled mine and spent a few months overall patching it, modifying it to work with mods and improve the setup. With modern tech and wiring, you can vastly improve the systems, most are inadequate and poorly routed.
For example I re-routed power to high drain devices, like the headlights and horn, through a modern power distribution box out of a late model Ford. Old wire no longer had to carry load, only switch relays. I now have a electrical system that works very well, but now that I have a better understanding of it, I would have further simplified it, and went ahead with a new base harness so I won't have to fix connectors and old wire later.
Either way you go your going to spend some money. I have a few hundred into my wiring just fixing the old harness, but I also had to tool up with supplies and equipment, and I don't regret the money spent as it was darn near a crash course in automotive electrical systems. I'm a lot more comfortable with wiring than I was, and you should see me soldier.
So personally, I'd go for the cheaper base harness so you can get most of the wiring as new wire and connectors, and then modify as needed, and that can even be put off once the base harness is in good shape.
