tub undercoating options
papy
hey all,
what have you all used for undercoating the underside of the tub? been reading up on the different options and they all seem to have many pros and cons.
should we be concerned about moisture getting trapped between panels and undercoating?
looking for more of a smooth Vs a heavy texture finish just to be abel to keep it clean. truck bed liner seems to catch a lot of dirt and doesn't wash off as easy as a smooth finish. still on the fence about any type of undercoating as i dont know enough about any of the available products.
thinking i might just stick to paint however hoping to get some insight from some members here.
cheers
bronkenn
Bronco Guy
Southeast Ohio
I have used POR15 on several projects and have been very satisfied with it. Very durable. I have it on a 20 year old restore and still looks good. It likes bare metal to stick to. It seeps into every crevasse. I would stay away from rubberized coatings as they seem to trap moisture under them.
papy
papy
i used POR15 on the frame, radius arms, and a few other items after i sandblasted them. stuff is truly amazing. i was considering POR15 on the underbody however i still have good layer of factory primer. only exposed metal are the floor pans.
i am steering away from any type of undercoating as i am hearing more and more about moisture getting trapped like you said. think i will just end up going with the trusted rustoleum or tremclad as we know it in Canada. goes on thick and you can touch it up with a rattle can when it shows signs of wear. relatively inexpensive and always available your local homedepot
JP
Bronco4x4
Raptor liner on my current build. I tinted it gray to match my galvanized frame.
papy
papy
nice to hear of some options. that PPG amerlock2 is interesting.
AC932
I've had good luck with POR 15 as well (over surface rust), but I've also started drenching my truck with fluidfilm twice a year to prevent corrosion.
When I first restored it, I used rustoleum rubberized undercoating...after four years all of that has flaked off revealing rust underneath. Avoid that crap.
papy
papy
i originally back when i was considering an undercoat or liner of some sort was considering that rubberized one. man glad i passed on that.
planning to go with an epoxy of some sort ppg
cheers
Bronco4x4
Forgot to mention my tub was sand blasted and epoxy primed prior to Raptor liner.
Steve83
Rubberized undercoating, FTW.
This shows heat-shield mats over undercoating over paint over primer over sandblasted original steel.
(phone app link)
POR15 is paint - not undercoating. Bedliner is hard polyurethane foam - not undercoating. Powdercoat is melted plastic - not undercoating. Primer is only a prime coat - not undercoating. This is undercoating:
(phone app link)
ransil
Fluid film type of material. Redo every year.
Sent from my SM-G960U1 using Tapatalk
