I did mine with herculiner from the auto parts store. I removed one body mount at a time. Taped up some of the cables and things and then used a wienie roller with a foam head to do most of the big open areas and then a cheap brush to hit the crevasses. It turned out good but I must confess I did not drop the fuel tank to get behind there YET!
I've been thinking about attempting the same thing. Is there a decent rust cleaner / inhibitor readily available? I'd like to clean it up a little before covering it. Thanks.
Have you ever seen how much rust happens where the rubber body mount touches the body? You are skipping the single place that needs the most protection.
If you intend on spraying upside down with POR or paint do yourself a favor and get 3M's PPS system. You hold the gun upside down, pull the trigger, and wait till the paint is coming out of the gun. You can then paint upside down without a leaking cup.
