New Tub Undercoating
C-Dubb
I will be getting a new tub for my 73' pretty soon and have been researching whether or not to undercoat and what product or combo of products to use. I have found lots of information on old or rusty tubs but not much on new ones. Any advice will be appreciated. Thanks.
Rustytruck
use a good seam sealer after you prime it and before you apply what ever you use for undercoating. everything Ford didn't do. They seam sealed the top side and not the bottom side and their seam sealer failed in the first 10 years and was far from the quality stuff used today. they had good primer but just didn't use it everywhere. the underside they didn't paint at all.
If you decide on a standard undercoating, use one that claims a little more sound reduction. Some rubberized versions make this claim.
If you want the killer combo and don't mind paying more, an application of both Lizard Skin products would be of great benefit
First apply their sound deadening product to the tub, then put a coating of heat barrier on top of that. They can be had in colorized versions too, which is how I'd like to do mine. Match the rest of the body color the best you can, and it won't look like just another undercoating.
And I would go all the way up the firewall and the cowl area if you don't mind the more textured finish being visible when you open the hood. There's a reason for going this extra mile.
You get a TON of both heat and noise through the firewall and cowl. Even Ford tried to minimize this with some sound deadener coating under the hood and a fiber insulation under the dash. It's not enough.
If you add long-tube headers to the engine too, your heat factor goes up by 5x and we jokingly (and sometimes not jokingly) refer to melted shoes on bare floors.
So that's what I'd do...;);D
1970 Palmer
I'd do a two part epoxy coating first. I'd spray every "nook and cranny", inside, outside, underside, basically any bare metal you can reach with a spray gun. Use a touch up gun to reach the tight areas.
I used some 3M panel bond on some of my seams. I'm sure they also have some quality two part sealers that are cheaper.
You really need to seal the bare surfaces before you think about heat and sound barriers, which are also important.
John
Triple Nickel
I just did mine. I applied epoxy primer, then lizard skin sound deadener, lizard skin heat shield, and raptor liner over that. It came out really well...longevity we'll see.
PDQ
Triple, or anyone using the 2 to 3 different coats of skin/ liner, how thick does that end up being? Did it complicate any mounting surfaces with that many layers?
Most of the coatings are not all that thick, but adding any brand of bedliner to the mix will definitely add a lot of thickness overall.
Not a lot of mounting surfaces to be effected I would not think. Even getting it on the body mounts is not grounds for disaster.
But I would keep it off of stuff like the small areas around where the brake booster/master mounts, and maybe the column too, though I don't see that as an issue.
If you are coating before finishing body work, I think it's a mistake for exactly the reason you're talking about. So no more rocker panel or kick panel work allowed! Finish that up and about the only thing where thickness can really mess with you is the tailgate.
I would not wrap anything more than a couple of layers of paint up and over the floor pan at the base of the tailgate, OR the latch side panels. Or if you really must get it up in those areas, mask off where the tailgate seals go, as well as all the hardware and bumper stopper thingies that work with the tailgage. It's much tighter in there than most think.
And of course, not all Broncos will suffer the same fate. But it's for sure "a thing" and so needs to be taken into account when working around the tailgate.
Presumably you won't be doing the door jams with the stuff, but the tailgate area and bed rails are often areas that get coated.
Otherwise there are not that many things that bolt to the body that have tight tolerances.
Parking brake cable mounts and pivots, but not that precise. Nuts and bolts on the firewall, but again, not that tight of a tolerance. Fenders, but presumably you are not coating up in there until after the fenders are mounted. Rear wheel wells don't have much but the backsides of the door latch plates, but I would try not to spray those directly.
Can't think of what else I'm missing. But lots of members here doing just what you're contemplating, so I'm sure if there are any pitfalls someone will have run afoul of them.
Jamie Chriss
This is what I did: I made sure the new metal was really clean, sprayed a good coat of 3M primer in every crevice, seam sealed, another coat of primer, two costs of Lizard skin sound, one heat, quick coat of primer, two coats of matching paint and two coats of semi gloss clear coat. And yes my neighbors love me
EPB72
Pleasant Hill, CA
Same process here but using SPI epoxy primer,,my neighbors don’t give a shit.. also coated the interior of doors .. Jamie yours turned out very nice.
1970 Palmer
I love the MY NEIGHBOR"S comments!
I guess we all deal with the same issues.
LOL
John
C-Dubb
C-Dubb
Another question, if I start out with primer does the e-coat need to come off completely or just scuffed really good?
EPB72
Pleasant Hill, CA
I'd check with whatever paint manufacturer your using ..more then likly scuff really good if its a good solid e coat ,also could test a spot with acetone on a rag to make sure it dosen't rub off..but again check with product manufacturer MSDS
What EPB said. Generally speaking though, the c-coats are primer coats, and just need to be given a good scuffing and cleaning.
But it never hurts to be extra diligent about getting info on a part, when you're going to be spending as much time and money as you will with a paint job.
sprdv1
REBEL
Neighbors. Who needs em. Lol
sprdv1
REBEL
most certainly....
EricLar80
I'm curious how you were able to flip the body over without damaging it? Is it as easy as putting moving blankets down and rolling it?
bronco561
Also curious as to how your were able to flip over the body. Would love to do that to undercoat my new tub
