Dusty said:
If you really want function over form, build the tube chassis to fit whatever drivetrain, suspension, wheelbase, center of gravity etc. that you want. Then skin it with Bronco panels after its built.
To build a tubular frame that matches the measurements of the stock frame and fits a stock replacement fiberglass body, in my opinion is a wasted opportunity to build something really special.
You said you wanted function over form. Then build it for function first.
Dusty
....gee.....I'm not really sure how to take this. I dont necessarily disagree with your suggestions.
If you (generic) want a rock crawler, then build one a dedicated one. That way, you can hang any body panels available; make your own; leave them off, modify existing, whatever. Doesnt even have to be a Bronco.
If you want a trail rig - build one for that. All the goodies.....on board air, welder, winch, invertor, etc., etc. (kinda like Crazy Horse). That's also very appealing. In that case, it's probably best to stay with a full steel or f/g body (protection from the elements) and stay within the confines of a mfg conventional frame build and body. Maybe bolster the rollcage a little. Plenty of those on this site too, and VERY nice ones that I would be proud to own.
Also .....if I may quote md_lucky_13 ... "I don't see any reason to use a totally tubular frame if you are going to try to use an entire body. "
"The advantages of building a rock buggy over an original framed rig are basically the care free "I roll it over and flip it back to the tires, no harm done" aspect of owning a buggy. You are basically nulling that by throwing an entire body over the top."
I agree with part of that. If you are going to beat one over the rocks. flip it, roll it, scrape, scratch it, dent, abuse - then the buggy is the way to go.....or even a modified original frame.
Where you (generic) get into trouble is trying to build one for double duty and serve as a daily driver......or even street legal. It's nothing but compromise and doesnt serve either as well as it could.
What I disagree with is the opinion that building a totally tube frame within the confines of a Bronco Body is a waste or a missed opportunity to build something "special".
I dont consider what I did with mine a lost opportunity to do anything.
The guy who built my chassis is a certified, well-known, well respected chassis builder in the mud (NMRO)/sand/asphalt drag arena. I wanted light weight, strong and safe. I got that. I didn't forego anything by having it built to welcome the Bronco body.
I wasnt building a rock crawler. (matter of fact - I very quickly point out the limitations of the chassis to viewers). When I contracted to have this built, it wasnt even a consideration.
I wasnt building the ultimate off-road trail ride. Again, similar limitations. I am sure that this chassis would probably handle much larger tires, affording me much more ground clearance.
A blower and carb are not the best configuration on the trail.
I'm sure it WOULD (with some minor modifications, blow through the desert pretty well.
I wasn't building a trailer queen/show truck - inspite of my "Trailer Special" insignia on the glovebox. I drive this truck. No, not 400 miles, as I have done before. Sure I show it, but I prefer to drive it. Is it the ultimate "cruiser"?.....no hardly.
Is it the national record holder for pro-street Bronco's ?....again, "no".
I built this truck to be a 4130 Chromoly blown bullet-proof street Bronco. Is it fun? YES! IS it fast? YES. Is it what I wanted? YES.
Is it for everybody? ...should everybody build a tube frame Bronco? NO
But I did, I am happy with it (absent some minor bugs) and it has held up under some pretty tough testing........
Also, I was told by the builder, that anytime, if and when I decided to sell the chassis, he had buyers in line.
mud racers as well as tough truck. The builder wanted to design the chassis around a "gutted" rear end (no floor). I wanted a street legal truck, protected from the elements (mud - if I so choose!) so I vetoed the idea.
I think you all gave him some pretty good advise and took him down the path when he wants/needs to go. I just dont agree with your opinions on the use of a tube chassis.
my .02
J. R.
