tuff stuff alternator problem
jrbronco
i bought a 100 amp tuff stuff 1 wire alternator of craigslist the guy said that it was new but it looked a little used to me but o''well.I ran 1 wire from the back of the alt to the siliniod and from the siliniod to the batt.Then i ran the other wire to a switch power.The problem is i am getting more then 18 volts does this mean the internal ragulator is bad
Initially, I'd say yes, it sounds like a bad regulator. But one of the others with more "charging theory" might have to chime in.
Since this is an aftermarket unit, is it truly a one-wire setup? If so, maybe you don't need that keyed wire on there. A true one-wire alternator is self-exciting and does not require a keyed source.
If it's not a true one-wire, then could it need one more connection, like a Ford 3G would? I'm just guessing here though, unless you happen to know exactly which part number alt you bought?
If so, we can look it up. I might even have the Tuff-Stuff book handy still.
Worse comes to worst, I guess a call to TS on Monday is in the cards. They're pretty nice folks and make a high quality product. And still build in the USA by the way! Not many can say that anymore. Only their Japanese branded products (like Hitachi and stuff) are bought in components from the source, chromed here in the states, then assembled here as well. I hope they're still in business!!!!
