- Feb 1, 2004
- 2,227
My sons 240Z has a Rebello 3.0 with triple mikuni's PHH44's. Savage motor
I a no expense spared 3.1L getting ready to go in. Should be 300hp to the wheels or so. Which will be a rocket ship of deathMy sons 240Z has a Rebello 3.0 with triple mikuni's PHH44's. Savage motor
The 3.1 is a monster !!!!I a no expense spared 3.1L getting ready to go in. Should be 300hp to the wheels or so. Which will be a rocket ship of death
Rebello is the name in the Datsun world when it comes to motors. I probably have heard of your son.
There are tons and tons of ecus brands, they seem to come and go regularly.Circling back to the original post, Brian and I have both been dealing with tuning chipped A9xx ECU's with remote support, and I've done some myself with a tWeecer RT using the house brand software, then Binary Editor, then switching to a Quarterhorse and using Binary Editor and later TunerPro RT. All of which had/have nearly vertical learning curves with a bazillion tunable parameters. I managed to get my previous 5.0 running with EDIS pretty well though it was never perfect- perfect being a carburetor in coastal conditions with ideal temperatures, which meant that my carbureted engine often had issues as well.
Now there is Haltech and Emtron which are very expensive and appear to be aimed at the high end race car market, then Holley and Edelbrock which seem to be more mass market oriented with (possibly theoretical) limitations. Then fringe players like Pro-M. All appear to have their own control software for tuning.
So when using a chip on an A9xx ECU one is using agnostic tuning software (Binary Editor and TunerPro) that is at once very powerful and insanely difficult to learn. And given the adaptive limitations of the A9xx series, assuming one is using a "normal" strategy AKA GUFB, that means a lot of learning. How do the various aftermarket packages from Haltech, Emtron, Edelbrock, Holley, compare? I guess I should mention Pro-M as well, since if you ask the owner of the company his product has reinvented the wheel and left his competition in the (rubber) dust. Except that so far it hasn't.
Note that I didn't mention the Sniper and other throttle body systems, or carburetors. For those who prefer that, have a nice day and find another thread to comment on. With all due respect you have nothing to add. Thoughts from those who know this stuff?
That’s really funny. I bet it would tell you that it’s tuned perfectly.There are tons and tons of ecus brands, they seem to come and go regularly.
Maybe ask Chatgpt to tune your A9xx ECU? Lol
Honestly it could probably tune it perfectly. If it was allowed to use the tuning software.That’s really funny. I bet it would tell you that it’s tuned perfectly.
Just today I got a brand new quarterhorse set up to start playing with for my new engine install. To be fair though I am going to lean on theEFIguy to help me along...Circling back to the original post, Brian and I have both been dealing with tuning chipped A9xx ECU's with remote support, and I've done some myself with a tWeecer RT using the house brand software, then Binary Editor, then switching to a Quarterhorse and using Binary Editor and later TunerPro RT. All of which had/have nearly vertical learning curves with a bazillion tunable parameters. I managed to get my previous 5.0 running with EDIS pretty well though it was never perfect- perfect being a carburetor in coastal conditions with ideal temperatures, which meant that my carbureted engine often had issues as well.
"...come and go regularly." That is the problem. I tried Holley's Projection back in the early '90's and I'm still trying more types and it's 32+ yrs later...There are tons and tons of ecus brands, they seem to come and go regularly.
Brian, keep in mind that you can't pull the ECU and measure across pins 46 and 26 in the harness connector because it's the ECU that's putting power on pin 46.MAF yes. Agree that the ecu must be receiving some signal (or exactly what it's supposed to ) because it runs like crap with the tps unplugged.
Engine runs as it should with the tps connected. Like I mentioned, tuner thinks the ecu is not receiving a signal because the datalog is not recording it.
Only question is can it run "properly" w/o the tps signal?
Obviously there is a tune designed to run the vehicle in the ecu.
That tune doesn't run the engine on its own. That tune does its thing when sensors tell IT certain things have changed.
O2, MA, IAT, etc, etc, and TPS inputs.
If these sensors aren't sending signals to the ecu then it can't command spark & fuel changes.
To me (rookie on ecu algorithms) , I believe the ecu must receive a signal from the tps at all times to command the engine to supply more fuel when you open the throttle just like an accelerator pump. Open the throttle slowly and you don't need that extra shot of fuel to prevent the bog (especiallyw/o a load).
Anyway, when I get 15 min today I will pull the ecu and check the voltage on the harness pins #46 & 47 (pin 26 is in there too but?) when moving the throttle plates w/key on. Just like on my trans controller currently shows, I should see btw 1v & 5v.
I believe it will even tho it's now not showing on the datalog (BE software).
