lsukevinc
As soon as i stitch on the ignition switch, the fuse (15 amp orange wire with yellow stripe) blows immediately. Last night i tried unplugging both flashers and it still blew up as soon as i turned on the switch. What is weird is after i plugged back both flashers, i decided to try the emergency flasher and they work fine. All of the parking lights work fine with the fuse blown as well. What could the problem be? The orange wire is still wrapped in black tape in the main harness from the factory. Could it be a problem with the turn signal switch?
When the fuse blows, i believe the turn signals are the only thing that does not work.
