Turn Signal Intermittent "Super" Cancel
jimmyv65
Intermittently, when turning right, my turn signals will "super cancel" all the way over to a left turn signal. It only does it on a right turn. The column is a 1974 column and everything in it is new. The turn sig unit is a dennis carpenter aftermarket. My wheel is on a grant adapter. I have the two pins for the canceling.
As mentioned, it works fine on left turns, and only has the issue occasionally on a right turn.
I am wondering if anyone else has this issue and knows of a fix.
Thanks!
mrdrnac
Its the roll pins more than likely. Sometimes you have to bend them in some so they don't contact the switch so hard. I've never had very good luck with the pins they tend to break off the canceling arms, not good. I made the stock canceling cam work on the back of my Grant adapter, it works much better.
J
jimmyv65
Thanks for the info!
gr8scott
Not a Grant adapter, but you get the idea.
ksbronco75
so I’m having this exact same problem. Left turn works, right turn triggers the left blinker. I see on that cancel piece it’s flush with the back of the steering wheel shaft, is that the trick? My overhangs about 1/4” of an inch. Makes me think the bottom circular part of the piece is tripping the blinkers possibly?
J
jimmyv65
For me, it definitely was the aftermarket wheel adapter. Mine had two pins in it and I was able to open them up to be shaped more like the factory one. That helped the issue.
So it’s only half on the part that it’s pressed on to? Or is yours extra short?
If it’s about the same size as the one in the picture, but is hanging halfway off, I would certainly think that’s part of the problem.
At least it can’t hurt to try to press it on the rest of the way.
Or is yours a different shape adapter completely?
There may be different methods to different brands.
ksbronco75
So here is mine. I ground it down some yesterday to try and reduce that lip hang over from a 1/4”. It’s under an 1/8”, buy im guessing it needs to be flush? I have an aftermarket steering wheel, I don’t know much about these “grant” spacers I’ve read about, I’m just using the pieces that came with my aftermarket wheel.
J
jimmyv65
Grant is an aftermarket steering wheel company and they make the most common adapter. In your pictures, that looks like a Grant adapter.
ksbronco75
Ok. So does the cancel pieces lip need to be flush with the back of the adapter?
BroncoJimbo
Long-term owner
North GA
I don't think the depth of the pins or cam is the issue with these Grant hubs. Rather it is the pins themselves and distance from the center of the shaft. I built a plastic plate so I could see what was going on. I posted about this in a recent thread on this same topic. You'll notice the cancel cam is already broken on the bottom.
I really like the stock cam idea and will try that next.
ksbronco75
I really like the stock cam idea and will try that next. View attachment 941882
Ha!! Maybe that’s my issue, I didn’t even realize it but mine is broken too in the same spot! I had two pins that came out of the steering wheel adapter but they made a god awful clicking noise, which was probably what broke my signal piece.
J
jimmyv65
Thank Jimbo. This is a good picture. If you have it, could you add a link to the other discussion in this thread? Thanks.
