- Jun 13, 2012
- 905
finally got around to installing my new turn signal switch that i bought from TBP last fall. The install was flawless however when i screwed in the turn signal handle i couldn't get the turn signal handle to go up or down - did not want to move. I backed out the handle and was able to to so. There is a sweet spot that i can get them to work but the handle is super loose (kind of just dangling) on the female threaded portion of the turn signal switch. I put my flash light on it and screwed it in and i can see when the handle is properly threaded down the plastic body/cam pushes forward ever so slightly causing the bind.
am i missing something here? perhaps a small piece of the internals that i didn't see when i took it apart that maybe fell down the tube? anyone else experience this - perhaps its a manufacturing issue?
JP
JP
