turn signal switch binding?
papy
finally got around to installing my new turn signal switch that i bought from TBP last fall. The install was flawless however when i screwed in the turn signal handle i couldn't get the turn signal handle to go up or down - did not want to move. I backed out the handle and was able to to so. There is a sweet spot that i can get them to work but the handle is super loose (kind of just dangling) on the female threaded portion of the turn signal switch. I put my flash light on it and screwed it in and i can see when the handle is properly threaded down the plastic body/cam pushes forward ever so slightly causing the bind.
am i missing something here? perhaps a small piece of the internals that i didn't see when i took it apart that maybe fell down the tube? anyone else experience this - perhaps its a manufacturing issue?
JP
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
I had the same issue when I replaced the switch.
You need to trim the end of arm, so it does not protrude thru switch.
New switch.................................................................Old switch
joeray
Just an old guy driving an EB for 35 yrs
I wonder if this is causing some of my similar problems. Thanks for the tip! I'll have to check this.
Quote: "A work in progress...50 years & counting...Cheaper than therapy."
Love it! You gotta love these old trucks to take the abuse.
