- May 12, 2012
- 1,975
Hey guys, having trouble with the wiring diagram on my new turn signal switch. The instructions don't say, but I assumed the colored wires are installed left to right into the plastic housing. After getting everything back together, I am getting a fast blink on the right side, and neither front or rear right signal comes on. After checking the fuse and replacing the bulbs, which really didn't need replacing, fast-blink still occurs. So I decided to re-wire the opposite of the chart.
Is it possible to take each wire, one at a time, and plug them into the male wire, and expect it to work? That is, without using the plastic housing? For instance if I connect yellow/black to one of the male connectors, then the next, then the next to see which one works? The reason I ask is because I can no longer get the left blink to even function, when it was working before diagnosing my fast blink issue.
BTW, both blinkers worked before I replaced the switch.
Thanks for the help.
