Twin Stick D20 shifting
ripcityracing
So I have this Twin Stick installed by the PO and I'm not sure I understand all the shifting options. Stick on Left for front and Stick on right for rear.
My question, Can I be in High or Low in the rear but in neutral in the front? The sticks seem to want to shift together although it seems that I can go High in the rear and neutral in the front although I am not sure because neutral for the front is really vague. It definitly wont let me go Low in rear without putting front in low as well. What settings should I be able to use?
Thanks in advance!!
Z Bronco
Was your D20 originally a J shift or T shift. The J shift (shift flags cut) will let each shifter be independent of each other when twin sticked. The T shift won't unless modified to do so. Go to JB Fab.com and look at his pictures of both the J and T shifters after twin sticking and you will see which one you have. I hope this helps.
