Twin stick question
Johnnyb
Flagstaff
I can't remember if my twin stick came from wild horses or @JB Fab , however there is a small metal plate that goes between the two shift rails. Newer kits don't seem to have this metal plate or at least it's not referenced in the instructions I can download.
On one end is a round hole the same size as the bolt, on the other end is an eccentric.
I can't find my instructions and my question is does it matter which rail has the end with the eccentric?
THX,
JB
JB Fab
If the shifter came from WH it will have 1/2-13 threads. If it came from us it will have 7/16-20 threads.
If you have a external interlock bar, then you have our aftermarket shift-rails.
It does not matter which end the oval hole is on, it just matters that it is not clamped in tight and can move freely.
Johnnyb
Johnnyb
Flagstaff
Mine has 7/16-20. Do I need the interlock bar at all?
Thanks,
JB
Johnnyb
Johnnyb
Flagstaff
Do you have our shift-rails?
I have purchased several kits from you, however I am unsure if this is WH kit or JB Fab. It absolutely has 7/16-20 bolt, but also has the interlock bar, leaving me puzzled.
Thanks,
JB
JB Fab
The 7/16" refers to the threads on the top of the handle (where the the knob screws on).
The external interlock comes with our shiftrail set, (the shift-rails and the shifters are 2 sperate kits).
Regardless of where you purchased them we are happy to help, please contact me directly.
Jon
