cheesenip73
- Sep 17, 2001
- 316
I just installed JB Customs twin stick into my dad's truck. We pulled out the T-case, opened it up and tried%) using a chopped up 3/16 ball socket allen wrench to loosen the set screw down on the shaft of the front shift rail without taking anything out of the case for 4+ hours. Found this idea on the boards somewhere in CB. NEVER WORKED. Ended up taking everything apart, pulling the shift rails and shaving them down so that the 2 detent rods between the rails could stay in there. I assembled it all back together and before we put the case back in the bronco it shifted very nicely. Now it is all hooked up and want to know how easy all of you twin stickers are having when shifting to all the options of Rear L - Front L, Rear L - Front N, Rear H-Front H, Rear N-Front L, etc. Ours is loaded on the trailor and we hand shift it into low. Do you have to me moving a little? Tell us your secret. I want to know that we did the conversion correctly.
PS. Now the front preload cover leaks oil. Are you supposed to put RTV between each shim?
