I have an AOD trans and it has an advance adapter on it and I have a T case transfer case. I have read there are things you need to do to make T case work with twin sticks. Is this the case when you use the Adapter? Also is there a twin stick kit that works better with the AA?
I have done searches on this but can't find much modern stuff only 10 years old and know a ton of modifications to fix things can happen in that time. Hopping to find someone with the same combo that can relay some of the knowledge they have learned.
