meadowblaster
- Sep 30, 2008
- 197
Hey everyone, I just got my motor running after having everything all apart doing the paint and body work. I bought a set of long tube headers from Jet Hot years ago. They had them on clearance, someone bought them had them weld O2 sensor bungs in, which I need for my EFI, then coated. Anyway, the passenger side is a two piece with two primaries slipping into the collector. There isn't any kind of gasket or clamp at this point, and like you would expect there is a leak. There is only a slight tick at idle, and mostly disappears above that. Does anyone else have this type of header or know of any kind of gasket or product to stop the exhaust leak? By the way, I have the long tubes into 2 1/2" pipe to a H pipe, two 2 1/2" Flowmaster 40 series mufflers with turn downs in front of the rear axle. It sounds awesome! As soon as I get my brakes bled and my steering column back in I can take it for a spin again for the first time in about 6 years, can hardly wait!
Thanks,
Thanks,
