September 1972
- Apr 27, 2017
- 136
If a computer controlled tranny takes more than .4 second for the clutch pack to engage excessive clearance is usually the cause and the pressure will double to the actuator from 75 to 150 and shift hard. Changing fluid is a no no because a war tranny may shift great because it right on the edge of slipping but the old fluid aged gradually along with the transmission. In 110 degree weather driving in stop and go traffic the fluid can and does hit upwards to 300F and you may notice it shifts differently, baby it under these conditions. A cooler won't help much unless it's a condenser sized unit with a large fan with anti drain back valves, even then it might be 250F.
A black art to quiet and preserve hydraulic units is a shot of gear lube, just a couple of ounces and never change the fluid. Adding powered graphite is good if the clutches chatter but knowing how much is the black art that a good tranny guy knows.
Good tranny guys never change fluid but charge you for it because their knucklehead customers want it done and the factory recommends it. They cut the inline filters apart and add friction modifiers if the metal it produces is excessive, that's what they are in business for which is to keep the thing on the road. It takes longer than a fluid change but they know what will happen if they did change it, your tranny won't last and you won't go back or recommend them.
The warranty runs out at 36K and that's when the tranny is supposed to be serviced. The factory uses fluids that we can't get, it has heavy metals and all the good stuff to make the trans last 36K in case a lead foot customer is driving it.
Take it or leave it but it's the truth.
