So I may just be being dumb but you guys have always steered me right in the past. Have been having some bad vibrations and clanking when putting into reverse along with tranny fluid leaking from the transfer case so I thought I should check the U-Joints.
Have been away at college for awhile so haven't been driving it too much but when I went to check was noticing some slippage and rubbing and saw that the inner U-joint on the H yoke was missing the external retaining clip and pushed to one side and had been rubbing the yoke. Looked like I should just replace it so I marked and pulled the driveshaft today and loaned a press from a buddy. Hours later and still couldn't get any of the caps off that joint. Started to work on the outer joint that hooks up to the tranny thinking that I needed to take that off first to get the inner one out but that didn't really make much sense to me. Is that the case and if so do I need to replace the cv joint inside the H yoke? Everything is pretty seized up now and thinking I might have done some damage to the inner CV or ball joint...but I'm new to the drivetrain so might not be calling it the right name but the inner ball joint between the two U joints on the spicer style shaft.
Is it worth it to just take the driveshaft to a shop and have them press it out and replace the joint or should I just give it a little more. I've mostly just been worried about damaging the yoke or shaft but might just be being stupid. I was planning on just replacing the one U-joint because it is only about a 5 year old shaft.
Any advice would be appreciated.
