Under hood storage box
Buckeye Rob
Hurst, TX
WILDHORSES
USA
Paul, what are the internal dimensions of the box you sell? I'm curious if it is deep enough to hold my bottle jack. Thanks
I think most smaller bottle jacks could be stored there. Here's the proto type box (that's why it's white) with a 6 ton next to it. Depth for the Z Box is right at 12". The handle fit as well but it was only an 11.5" handle.
67RT
Revival: Any water issues on firewall>?
So I just ordered one of these boxes. In hindsight I am wondering where the rainwater goes now. Does it drip down the cowl and cause rust??
Very good question. First though, water gets up there all the time from underneath as well, so it's not like it's a completely dry and rust-free area, but with the lid in place you are seemingly more likely to get more water slipping by through the hood slots and on to that area.
The good news is that there is drainage still, but the bad news is that this drainage has never been the best, and why rust is an issue in that area in the first place.
The rubber seals around the stock vent are primarily to keep engine compartment fumes from entering the cabin, but certainly do double-duty as a way of reducing water intrusion.
I've never tried it, but I don't see why you could not also use the stock type seals either glued to the lid of the Z-Box, or glued to the underside of the hood. It would make total sense. Assuming of course that the lid is even remotely at the same height as the stock vent. Which I've never measured. Don't know about the others though, so maybe they can chime in.
As a side note, it's a good idea to also try to seal the box against the cowl too, as there is no real gasket or seal, other than a tight fit, to keep standing water from leaking past the interface. Some silicone sealant would work just fine in that case.
So maybe someone can set a stock seal up in place to see how it fits? Be good info.
I had one in my trunk up until Monday, but left it back at WH so don't have it to measure or compare.
Let's hope for a positive answer to your question.
But you may be the one to provide it!
No Hay
The box and lid I bought from WH touches the underside of the hood. It may even push the hood up, I can't see the hood lines deformed though. Definitely no room for stock vent gasket.
badmuttstang
redneck grease monkey
Well that sucks I know the one on the site is the same one that was produced before or atleast looks just like it. I can't remember anyone having this issue before could you sand down the lip on the lid and liner to make it sit lower. You should be able to run a foam gasket tape between the liner and the cowl just need to figure out what thickness and then go to a Lowes or home depot. Does the liner screw down to the cowl? If not that and the foam tape would really help with sealing it up and could allow for a good foam tape just get one made for automotive use closed cell foam usual black in color.
67RT
I will figure out a way to seal to the cowl. I didn't know it was so tight. May return it and go back to the vent box as I do not drive in the rain. Truck sits outside covered and want to minimize leaking into cab..
