UPDATE on caster alignment
chuzie
The rear had 2 inboard and 2 outboard. I replaced the outboard hydros with nitros. Night and day difference. I left front alone though. If you don't plan to use for off road / rocks you may consider going full nitrogen. I just wanted to keep it softer for the rocks.
chuzie
Absolutely. The duffs design had me crunching shocks and bending lower tabs on truss. I moved the outers under the axle tube. Made out of 3/16 or 1/4 wall square tube. The inners were okay though
Casey835
Casey835
Cool thanks....I think I'm gonna try couple of those on rear and take it from there.
chuzie
Keep in mind relocating the outboards was strictly for articulation. M95s to fit in the original outboard location would have stabilized the rig fine. Keep in mind shock dead zones when starting from scratch.
Casey835
Casey835
Alignment
I'm within 4-6 inches of outboard shocks being fully compressed just sitting maybe even less
Casey835
Casey835
Just so you kno Im already considering cutting the rear quarters but then again I knew I would eventually do it when I replaced them
Casey835
Casey835
I find myself wanting to drive over things and fenders aren't very accommodating
Casey835
Casey835
So I finally got around to it, I cut and turned the knuckles to add caster. It didn't really take long to do and was well worth it. I intend on getting after results from alignment shop when I get a chance just to verify where I'm at compared to the measurements I took. I turned both sides roughly 6 degrees and went back to a stock c bushing.
