I was sent a PM from another board asking to come here and help out. You're not going to like what I have to say.
First off I build hydroboosts and create installation kits for vehicles. I even supply 2 different Bronco Set ups.
The first problem you're running into is using Lincoln boosters. Is there a reason why this hydroboost was chosen? The problem your running into is no one makes fittings for them. Reason being is they are 5/8 and 11/16th "o'ring" ends. Used only by Ford and only for a few years. There's no money in making a fitting for them. You can't "safely" tap into a hydroboost.
I'd reccomend you use any GMC hydroboost of any 1980+ Vehicle in any future conversions. These are 16 and 18mm "o-ring" ends and several markets supply fittings to convert them into AN6 male. From there any hose maker can make you a set of hoses. There's also the advantage of the bracket being removable by a large nut and a new bracket can be made or remachined. Whereas the lincoln is a set mount and not much can be changed.
I don't check these boards often at this time. I'll try to if you have any other questions. My e-mail is
Vancopbs@aol.com and phone is 323-563-1588. Don't be worried about calling, I love helping guys get their rigs going and it won't be turned into a sales call.
Van
