trailpsycho
- Dec 11, 2003
- 4,856
OK, I have been running the RJM headlight harness for several months (~8-9) and it has been great (the Cibies are awesome, everything has been great until the last few weeks). However in the last couple weeks the headlights have been acting up again. Actually, the headlights stay on but flicker in intensity. When this occurs, the guage cluster lights dont work and I have no tail/parking lights--very bad. THe problem has been intermittent over last several weeks (mostly if I hit a hard bump--which got me thinking that I had a short), now its all the time. I have looked for shorts and the wiring all looks good. The brake lights still work as do the turn signals and hazards. I know that the aftermarket harnesses use the stock switch to turn on off the power to the headlights via relays. If the headlight switch were bad, though, you would think that it wouldnt trip the relay at all and hence no lights. As it is, I have lights, but they are flickering (prob due to ??/switch). I know that common culprits for these sort of things with the stock wiring are the headlight switch and the dimmer switch. I was hoping to get some feedback to this gremlin before I just started to replace switches. Another interesting thing that occurs now when the switch is turned on is that the amp meter is extra quirky...yes, more than normal. I have checked all my connections with the harness. My fuses are in OK shape. What do you guys think? Relay?? Headlight switch?? Dimmer switch?? Another thing is that it has ben very hot here recently, not as hot as what it used to be down south, but hot for the midwest...I know the stock harness has its heat issues....soon enough the Centech will go in, but this is my daily driver, so opinions please I need to get this fixed.
