Upper door weather strip with soft top?
Yooper74
I'm going to be running a soft top. The weather strip i have for the upper door is one piece that appears to attach to the old hard top and window frame.
Should I just trim the piece I need off for the window frame and use that by itself for the door to window frame part?
Cecjap
Door seal
I purchased this from Amazon and NAPA, works great. No glue required
Y
Yooper74
Thanks guys. Both look like great options. Figured it was pretty straight forward.
Rustytruck
I wrapped flat foam weather stripping on the steel support bars and put the top over it. made a padded seal for the door to seal with the top.
