427SideOiler
- Oct 25, 2016
- 8
I am swapping out my 75 Automatic column, for a 79 E Van Tilt Column. The conversion is going well, except I have found that the upper shaft spring that sits just below the steering wheel on my 75 Column- does not fit in to the pocket of the 79 Tilt column- the 79 has that rotating cancelling cam assembly and the 75 spring seems to be too fat/wide and will not sit down in the pocket- there must be a thinner spring for this application? Does anyone know what is the correct spring for a 79 Tilt column and where to find one. I have searched but no luck so far. Any help would be appreciated.
