Finally putting my ZF 5-speed in my bronco after the parts have been sitting for a decade.
I bought the complete BC broncos kit.
I have the transmission mounted to the new crossmember and installed in the bronco while I measure and cut the trans tunnel
I’m taking extra measurements and something doesn’t add up
The distance from the front of the bell housing to the frame motor mounts is 12”
When I measure from my engine from the bellhousing mount face to the motor mount I get 12-1/2”.
The trans crossmember only goes in one way. I’m considering slotting the holes in the trans mount so I can slide the trans back.....
Thoughts?
Thoughts?
